Millers rules (again)
I was reading
https://www.software3d.com/Millers5th.php
and I do disagree , because it does overlook at least one pair of enantiomorphous polyhedra.
I don't really know how to interpret the lines in the diagram. so maybe I am mistaken.
I see A, BL,BR CL and CR as independent parts. that all could be added to a polyhedron individually
they are only related that BL and BR are a pair of enantiomorphous cells, also CL and CR a pair of enantiomorphous cells.
My first interpretation is that Millers 5th rule doesn't really rule out including both polyhedra in a pair of enantiomorphous polyhedra.
I think the first line of rule 5 refers to icosahedra like Ag1 that combines the 2 unconnected icosahedra A and g1 both having full icosahedral symmetry and are unconnected.
the exception in line 2 refers to i think the icosahedra f1 that combines the icosahedra f1l and f1r (that are all only vertex connected)
I assume that in "the 59 icosahedra " the rule to include only one of a pair of enantiomorphous polyhedral is just implicit. (like it also makes other assumptions that e1,e2,f1,f2,g1,g2 are connected icosahedra)
so what now?
I think it is reasonable to include only one polyhedron of a pair of enantiomorphous polyhedra.
But in the given example it is interpreted to strong
Valid stellations, ignoring the exception and enantiomorphic repeats, are: CL, BL, A, CL-BL, BL-A, CL-BL-A, BL-A-BR, CL-BL-A-BR, CL-BL-A-BR-CR.
and you add then CL-CR, BL-BR, CL-BL-CR-BR.
this combines to the
reflexible stellations are A, BL-A-BR, CL-BL-A-BR-CR, CL-CR, BL-BR, CL-BL-CR-BR.
and the chiral stellations (preferring the L over the R cell) are CL, BL, CL-BL, BL-A, CL-BL-A, CL-BL-A-BR
and excludes the stellations CR, BR, CR-BR, BR-A, CR-BR-A, CR-BL-A-BR
I am not sure why he combination A-Cl is not included (I guess it comes that I see all cells as independently possible)
My worry is that no polyhedra of the pairs BR-CL , BL-CR and A-BR-CL , A-BL-CR included.
in my opinion at least one of each pair should
so what now?
Re: Millers rules (again)
Miller was trying to reduce the set to something manageable, and I suppose reduce the number of impracticle polyhedra. Sure, you could allow all possible combinations of cells, and you'd get 2^N - 1 stellations, for N cells (presuming we skip the empty stellation with no cells selected), so it explodes pretty quickly. Even Miller's rules explode pretty quickly after the icosahedron.
There are also other rules to identify interesting sets of stellations, and there's no correct rules. Miller's rules is just one, and well-known thanks to Coxeter et al. Interpreting what Miller meant by his 5th rule is the question here.
The lines in the diagram mean they share a face. So A-CL would not be allowed because they don't share a face (would need BL to connect them). It would be two different cell types floating disconnected in space (but possibly sharing edges). It would be rules out by anyone's interpretation of Miller's rules. But you can still select those cells in Stella and see what it looks like if you want. Same for the other combinations you mentioned. They are still stellations in my book, but there's so many combinations that we have rules to reduce the number.
Rule (v) remarks that "But we allow the combination of an enantiomorphous pair having no common part (which actually occurs in just one case)". Any interpretation which allows more than one such solution to the full set is therefore wrong.
There are 12 cell sets (distinguishing enantiomorphs), so 2^12 = 4096 distinguishable selections. Of these, one quarter, i.e. 2^10 or 1024 are laveo images of the dextro set, but only one d and l pair have no common part.
Does the "just one case" refer to the cell sets f1 (=f1d+f1l), or to the stellations which comprise only these cell sets? Thanks to the "no common part" condition, the solution set is the same either way, so the question is moot.
Any interpretation which suggests something other than 1 solution, and 1 only, for rule (v) must in fact assume a different rule.
Guy. Guy's polyhedra pages
The "just one case" comment only applies to stellations of the icosahedron. All the interpretations I know of satisfy that for the icosahedron, but differ for other polyhedra. The icosahedron has only one chiral cell, and the "just one case" refers to a stellation consisting of both left and right versions of that cell.
I think it was Richard Stratton who pointed out that "as much symmetry as the whole figure" actually makes the exception moot. If you take away one of the chiral parts, you lose your reflective symmetry.
The 59 icosahedra should be just a first introduction but slowly is it became the final reference for stellations.
I think one of the big problems the authors faced was;
What about the hollow polyhedra?
I think they (duVal?) just decided all single celltype polyhedra are valid polyhedra (so e1, e2, f1r, f2 and g2) whether they are face connected or not (body connected in the notes to the plates, a much under referenced part of the book)
Du Val just accepted them without comment. (Except mentioning in the non reflexible section that f2 must be present if both e2 and g2 are present and cannot be present if neither of them is, not sure why he didn't apply this to the reflexible icosahedra, )
Combinations of cells types needed to be bodily connected (except f1 that is why i think that f1 is the exemption referenced in rule 5)
Therefore i conclude that the first line Miller rule v has nothing special to do with enantiomorphous pairs.
If i am correct the only hollow icosahedra that are body connected troughout (single body) are e1f1g1 and e1f1rg1 (e1f1g1 is Wheelers Labyrinth )
And with this rule (all valid icosahedra must be a single body ) quite a lot of hollow icosahedra would be disallowed. (Haven't counted them but my guess would be around 30) and the not single body icosahedra (like f2 and g2 are the most dazzling.icosahedra)
When in a cell diagram there are two independent pairs of enantiomorphous cells (so any combination can be added)
There are 9 combinations to consider.
So for example we have an polyhedron B and we have the cells c1L, c1R, c2Land c2R (and maybe other c cells) that could be added we should concider
(Reflexible) Bc1, Bc2, Bc1c2,
Bc1c2L Bc1Lc2
Bc1L, Bc2L ,Bc1Lc2L,
and one of Bc1Lc2R / Bc1Rc2L
Bc1Lc2R / Bc1Rc2L is an
enantiomorphous pair and differs from the other combinations
Which of the two should be included would be a long discussion but that one of them should be included is the point i want to make point. (Little preference for Bc1Lc2R )
Bc1c2L Bc1Lc2
I think you are confusing 2D faces with 3D cells. For example cells c have handed faces but there is only one type of c cell.Whogius wrote: Thu Jul 10, 2025 10:57 am When in a cell diagram there are two independent pairs of enantiomorphous cells (so any combination can be added)
Bc1c2L Bc1Lc2
No, I think he's referring to the example on my page about Miller's Rules, not the icosahedron.guy wrote: Fri Jul 11, 2025 3:34 pmI think you are confusing 2D faces with 3D cells. For example cells c have handed faces but there is only one type of c cell.
I was more refering to a possible situation . Not to any really allready found situation
(although I think it does occur in the stellation of the Triakistetrahedron ( * 6 6 3)
(option request for stella - list of the stellations, stella now only gives the count while i would need the data, or did i miss someting again)
Not sure what count you're referring to. You mean on my webpage with stellation counts for various polyhedra? There are usually trillions, so listing them is not so practical. Or are you referring to individual stellation cells?
O was referring to a particular stellation
The one for (* the dual of 6.3.3
6 layers
9 (7, 2) cells
3
21 (17, 4) mainline
188 (52, 136) miller
Icosahedra.
Just within a reasonable amount.
And the lowest one with 2 chiral cells.
https://www.software3d.com/Enumerate.php
6 layers
9 (7, 2) cells
3
21 (17, 4) mainline
Icosahedra.
