Work in progress
Work in progress
Post by Ulrich » Wed Nov 28, 2018 7:52 am
This is the sixth stellation of my model of the great snub dodecicosidodecahedron, which is No. 115 in Magnus Wenninger‘s book „polyhedron models“. Nine further stellations are to come. The edge length will be 30 cm. There are 15 colours, 6 for the snub triangles, 5 for the icosahedral triangles and 4 for the pentagrams.
Re: Work in progress
Post by robertw » Thu Nov 29, 2018 1:48 am
Looks great! Must take a long time. Looking forward to the finished model.
Post by Ulrich » Thu Nov 29, 2018 10:03 am
Thanks! I‘ll keep you current
Post by Peter Kane » Fri Dec 07, 2018 10:07 am
Awe-inspiring! What will the radius be? I've seen several of your models in the past, but previously, I've only considered the holes in the faces to be decorative. Having spent a few minutes studying the current image, I see that the holes also permit a better appreciation of the structure of the polyhedron. They allow you to observe the intersecting faces in a similar way that the models with natural holes (like W 63) do. This might be an alternative to using transparent sheets. I guess I'd need a laser-cutting-thingy though (are you listening, Santa?).
Thanks for sharing.
Post by Ulrich » Mon Dec 10, 2018 10:29 am
The diameter will be 396 mm. You‘re right, the pattern is based on the stellation diagram.
A laser cutting machine works well and can accelerate the process a lot. I could gather some experience in the past. The results are very precise but a little „sterile“. And although it can be rather painful, I love cutting the paper by hand with my scissors and knives.
Here is stellation no. 10:
Post by Ulrich » Mon Dec 31, 2018 11:35 am
This is stellation no. 14.
I think I'll finish it next year.
Post by Ulrich » Mon Jan 14, 2019 8:16 pm
This is the finished model:
Post by robertw » Tue Jan 15, 2019 1:18 am
Well done, looks great!
Post by Ulrich » Sat Jan 19, 2019 7:31 am
Thanks!
W116 is in the works
