Rhombicosidodecahedron model from cherry wood
RTChoke
PostPosted: Thu Jul 09, 2009 3:30 pm    Post subject: Rhombicosidodecahedron model from cherry wood Reply with quote
I started making a Rhombicosidodecahedron model from cherry wood, cut out pieces on my CNC machine and made some jigs to hold the pieces to get the bevel angles cut. I assembled the pieces and discovered that very small errors create problems! The triangle pieces seem to be the main culprit, I guess I need to start refining my technique a bit. Cutting the pieces on the CNC machine was the most time consuming, doing the bevels went pretty quick using the jigs, just a lot of repetitive cuts (while making sure not to get bitten by the saw).
I posted some pics in the other forum
http://software3d.com/Forums/viewtopic.php?t=117
along with my questions about making dxfs from the program. I got that all figured out, and had at it.
Here is the set of piccies http://s707.photobucket.com/albums/ww79/RTChoke/Rhombicosidodecahedron/
hamp856
PostPosted: Wed Jul 27, 2011 11:12 am    Post subject: Reply with quote
were you ultimately successful? I have just started making these objects. Lets share notes.
Hamp
hamp856
PostPosted: Wed Oct 26, 2011 11:32 am    Post subject: CNC machine Reply with quote
I have found a simple solution to build polyhedra in wood. Buy a simple Machinest protractor. These can be accurately set to 2' minutes or arch or 1/30th of a degree. Use this to set a table saw blade. I have done it and it works great. Grissley has a protractor for about $50. Get the one with the dial. There are more accurate ones on ebay.
Hamp
zohaa
PostPosted: Wed Oct 15, 2014 11:14 am    Post subject: Reply with quote
Have you tried gluing the plywood polygons together? Might need reinforcing strips behind each joint, pre-glued to one polygon like tabs on a paper model. Those would also need to be carefully profiled with the right angle.
_________________
http://www.unicatt.it/
testking.co.uk
http://www.hitachi.com/
hamp856
PostPosted: Wed Oct 15, 2014 7:07 pm    Post subject: Reply with quote
I now use upholstery staples. Works great.
hamp856
PostPosted: Wed Oct 15, 2014 7:09 pm    Post subject: Reply with quote
go to my web site:
http://hampstevens.com/
and you can see all sorts of wooden polyhdera I have built.
